car stalls
ricturbo
when I first press gas it stalls alittle and while driven it stalls when I let off gas . I put new tps and iac on car tbs .41 . do I need to set iac torx screw? ser engine light went out when I installed new sensors.
Anyone have a suggestion on what I need to do to stop throttle hesitation?? when I give gas and let off of gas..
Well I was hoping someone had a solution for the problem . I turned torx screw till one thread showing like 1 thread said , and ran car for 1 min and started back still stalled when gave it gas. I read some thread on how to reset iac but didn't understand I have a multimeter , is there a way to set iac with that??, or would iac even make it stall
Buy a scanmaster.
Best tool u can have.
U may have another problem
Not throwing a code. U can see it with a scanmaster.
I was
Buy a scanmaster.
I was planning on driven this car daily , are they reliable , or am I going to be working on car daily ??
I was
You will get a diff answer from everyone
Too me. As a daily driver. No! !
Daily drove mine for 5 years with no issue.
Sent from my SPH-L720 using Tapatalk 4
I think it's like any 26 year old car. you drive it you'll work on it, especially if you run it hard. I used mine for a 120 mile commute for two years when i first got it never left me stranded but still add issues I had to address to keep it going 86-87 computor cars were just in the infant stage so a lot have progressed what help me was to have two of every thing and the tools and ability to diagnose and keep running it is a labor of love for these cars.yes they can be made dependable.I would be more worried about were i had to leave the car everyday without it getting stolen.
what about the stalling any ideals??? just fixed the bad bearing after church and found roter grinded down on inside is that a bad caliber or not ,put new roter on . I also noticed tran fluid leak not at rad fitting , but looks like maybe undr moter there are no fittings there ?? right
without knowing what what your iac numbers are your kind of flying blind and just guessing do you know what chip your running if i had to do something with no other information i would disconnect the battery for a few minutes reconnect and let the computer relearn see if that helps.sounds like a tip in stumble taking off when letting off and dieing i'm not sure but if you fix one issue the other is probably related
Stall Could be vac leak, does it happen when you come to a sudden stop? Make sure the transmission line is not rubbing against the downpipe. That happened to me and it wore a hole in the trans line, started spitting trans fluid all over.
