Hey guys i was wondering if you might be able to help me out. i sent patrick a pm so we will see what he says but till then i figured i would post here as well.I was hoping you can help me out. Im trying to read up on upgrading turbos. I have a hotair car with a TA-54 that i had modded by precision turbo along time back. well anyways i was reading up because i wanted to maybe go bigger and my question is whats with the carbon seal backing plates. can you please explain what this is to me. From my research I found that for the most part the later turbo's being designed use dynamic sealing so i can no longer upgrade because we cant get the carbon seal backing plated anymore. I was told that the carbon seal backing plate works best for a draw through type induction system (like the hotair cars) and since pretty much all turbos are using the dynamic im screwed. From what i have read it looks as if i run the dynamic plate it will draw oil threw the turbo and push it into the intake but if i can run the Carbon seal backing plate it will be fine. can someone help out. i want to upgrade one last time and call it good.
