CAT Cranks
Weber Racing did my motor and knew what they needed to do with the Cat crank. Also I know DLS offers the Cat cranks so they can't all be that bad.;)
http://www.turbobuick.com/forums/engine-tech/231459-cat-products-have-you-used-them.html
Just wanted to clarify some thing. DLS does not stock CAT cranks. His stroker kit contains a BA performance crank.
I have stroker crank from DLS and it came with a woodruff key in it. The crank needed no additional machine work.
Ok thanks for the clarification...I must've been thinking of somebody else.:o
Im sure its exterally(99.9%sure) balanced crank so you'll need a BHJ neutral balanced balancer and JW or Cat neutral balanced flywheel .Cat's cheaper
It think you've got it backwards. Internal balanced cranks need the neutral aftermarket balancers and flex-plates. External balance uses the stock style stuff. :) Most of the aftermarket cranks are the internal balance type except for Eagle who does make an external balance version, but no stroker from them yet :(.
your right Sleeper my bad its been a year since i had my done brain fart....;)
