G GNXDad Member Joined Sep 17, 2004 Aug 7, 2010 #1 Any suggestions on how to find the short or problems with why this fuse keeps blowing without tearing the dash out, etc..????:frown:
B bmackinnon Active Member Joined Feb 24, 2005 Aug 7, 2010 #2 Swap out the ignition module/coil pack with known good spares?
salvageV6 Daily Driver Joined May 25, 2001 Aug 7, 2010 #3 Unplug the connector to the Ign. module under the hood. Unbolt the small locking screw first. Once unplugged see if the fuse holds, if it does it's the module assy. itself as mentioned.
T TurboBob Resident mad scientist Staff member Joined May 24, 2001 Aug 8, 2010 #4 agreed, the CCCi fuse feeds only the ignition module, and nothing else. So its the module, or the wiring to it. Bob
D daturbosix Member Joined Apr 15, 2003 Aug 8, 2010 #5 yup. module.. i feel your pain, i just went through this.
G GNXDad Member Joined Sep 17, 2004 Aug 8, 2010 #6 salvageV6 said: Unplug the connector to the Ign. module under the hood. Unbolt the small locking screw first. Once unplugged see if the fuse holds, if it does it's the module assy. itself as mentioned. Click to expand... thanks, that was the issue :biggrin:
