mario65
Hot Roddicus Supersonicus
- Dec 29, 2004
Thanks Matt thats some great info.
You just bought the afx spindles and you said the C6 calipers bolt on fine with 13.5 rotors? That sounds too easy.
I ran 13" rotors on a 17" ZR1 rim on a Typhoon that was the wilwood LS1 setup and it was cutting it close. 13.5" has to be right on the edge.
The front and rear springs are now hotchkis so its lower than that pic. I have a 3.5" pinion snubber that I hit on big bumps and dips. Otherwise it rides along fine with no bottoming. I have zero rub and I did roll the rears and removed 3 trim screws on the top and held down the trim with the two lower screws and double sided tape and it looks and works perfect.
The front was about an hour with a 4" grinder on the a frame and brake line brackets. I rub on the inner fender at full turn.
Nitto 555r 315 DR's are alot narrower than the new Nittos. They look good still on a 10" rim and with 4.75 backspace I dont EVER rub on the frame. I have 2 more sets of these DR's so I actually tried them not expecting them to work and they did. The 315 DR's are about 1/4" wider on each side than 275/40/17.
