matt69olds
Ain’t no feeling like Oldsmobling!
- Feb 10, 2008
Once again I come to dip my cup in the well of knowledge!
Is there any way to change the part-throttle shift points? The trans makes the 1-2 shift at 15-18 mph and makes the 2-3 almost immediatly after. It then makes the 3-4 at 45ish. I rebuilt the trans 3yrs ago with CK shift kit, servo, governor, good band, 10 vane pump,etc. Valve body code is BR3, factory TV cable goemetry, car has 8.5 rearend with 3.73 gears. The trans works great, the only problem I have is the shift calibration. It has done this since day 1, I can live with it if its a big hassle to correct. Thanks.
