Quick run down, 36lb injectors matching TT chip, RJC plate, Dutt neck, hot wired 255 lph pump, single into two exhaust. KR keeps creeping back when I fill up with 93 octane without any type of octane booster. I had my chip adding 20% fuel and retarded the timing 2* or so, this got rid of KR as long as I had some type of octane booster or toluene in the tank.
I'm only running 16lbs of boost. I'm going to order an ALKY kit, prior to this, can I use a manual boost controller to turn down the boost? I have a new one in the box, just haven't installed it yet. I'm not sure if I need an adjustable regulator or can just use the controller.
