Chicago Trading Post III
Selling a polished dual 3" GN1 exhaust. An awesome exhaust for our cars, nothing looks and sounds better. Only getting rid of it so that I can put my car on a diet and get creative with how I route my exhaust by the fender.
Comes with the main cat back pipes, mufflers, tail pipes, (4) band clamps along with (2) turn-downs in case for whatever reason you don't want to run tail pipes.
Couple quick things:
The right tail-pipe does have a small ding in it, just through putting it on and off a few times. Also, the right tail pipe has a bracket that goes into the factory slip in exhaust hanger. For some reason, that bracket is a little off. This is how I received the exhaust. I was able to get it into the factory hanger but it might need a little heat and adjustment, or just some good wiggling as I did. I just left it as is as it worked fine for me. Lastly there is some of the exhaust adhesive on the muffler ends for sealing the band clamps, totally just reusable.
Retails for $735 if you include band clamps, selling for $500+ shipping if needed but prefer a local sale in Chicago.
Sold my 1987 GN due to health issues and have the following new and used parts for sale. I am located in Sparta, IL.
New Parts:
Gas line filter Offer Part # FF3504
Fel-Pro Cylinder Head Bolt set Offfer Part # ES74022
Fel-Pro Exhaust Manifold Gasket Set Offer Part # MS 90508
KIRBAN CUSTOM CUT PLUG WIRES $50.00 PLUS RIDE
Used Parts:
Master cylinder and high pressure lines for Hydro Boost. Offer
Stock GM knock sensor used Offer
Set of stock heads off 1987 GN. Offer
Stock O2 sensor Offer
If no interest in used items they will be going to salvage yard.
Will PM pictures if interested. Thanks Doug
Selling a "30 gallon" fuel cell for $600. It's a metal skin with a bladder inside made by fuelsafe.com/ It was designed for stock location, but will need some tweaks to make it work. There's a couple pics in this link - http://www.turbobuick.com/threads/performance-parts.385938/page-2. Also attached are the dimensions. I did the math before and it should hold about 30 gallons, but please don't bang down my door if it hits full at 25 gallons.
Have a nice set of front Wilwood 11" Dynalite brakes. Comes on a set of spindles.. $325
Dont want to ship..
IMG_20160613_173025359_TOP.jpg IMG_20160613_173035869.jpg 2 - 235/60/15 BFG Radial T/A tires slightly used - $100 for the pair
30 gal stock location fuel cell (good for E-85) - $600
Retails for $735 if you include band clamps, selling for $500+ shipping if needed but prefer a local sale in Chicago.View attachment 275743 View attachment 275744 View attachment 275745 View attachment 275746 View attachment 275747
This is sold.
Selling my precision TE-44, still on the car and working fine I'm just going bigger $500.00 and I have a set of 42.5 injectors for 200.00 buy both and ill throw in the chip for the injectors
will take off the car when I have it sold.
Tim
South Bend, In
Got a core 200-4R trans with a BRF valve body. Supposedly less than 1000 miles on it but it is burned up. $150? I need to move it out of the garage... I'm sure someone out there wants the BRF if you want to pull it all apart.
Do you still have the tranny?
Sorry, I do not. I sold all my parts as a lot to Turbo89 I think. Maybe he still has it.
Vacuum brakes - The brakes, pedal and aluminum vacuum block for $100. The booster leaked a bit when taken off and should probably get a new gasket.
Also I need a vacuum block without the brake port on it.
