Chip for stock injectors!
jdpolzin
Looking for a good chip for stock injectors!! Let me know what you have! ----Jeremy
I have 3 chips that i can sell you as a package deal, or you can pick out which ones you want.
Thrasher 92 street chip
Thrasher 108 race chip
ATR Pitbull about 100 octane chip
The only thing to run the thrashers is you must have your fuel pressure set at 45psi. 92 is for 92 octane 108 is for 108 octane
20.00 each or
all 3 for 45 shipped in the usa.
I can check to see if these have antitheft today if you like, these are all for stock injectors.
I have another chip that i was running a stock turbo and IC, belly full of 104 unleaded, radial tires and running 12.70 at 110.9
But that one i would have to charge more for.... 35.00 for it and you will be able to run 16psi of boost and turn the fuel pressure up on 91 octane, 22 psi on 104
Let me know
BW
Quick6, I have decided not to put my adjustable FPR on so those chips will probably not work for me. Basically, I am trying to keep the car as stock as possible and, after some advice, I have decided to pull the Hypertech chip and replace it. Basically, I will have to have something that will work without adjusting the FP and will work on 93 octane gas! Thanks ----Jeremy
If you've never driven with a Thrasher chip, it's a nice driving chip. You can run 15-17 lbs of boost. For $20, I'd go for it and put that adj. reg on. You can remove it in 5 minutes and put your stock chip back in for shows, etc.
I think Scott231 sells a Thrasher that will work with the regular FPR.
Thanks ES1, I'll try to contact him! John, yeah I know I would run better if I did that but i just dont want the hassle! Thanks, anymore ideas?
Well, Scott doesnt have anything for me so does anybody else? Thanks!! ---Jeremy
Definitely get with Eric, he can get your car dialed in.
Check my sig for his website
BW
$30 gets an RA stock injector 93 octane chip sent to you. Email me directly if your interested. Thanks.
Mike McCoy
Mike - any word on my refund yet or how we are to make my situation right ? I got sold a $30 bracket here that is useless 'cause the throttle mount is cut off....
Sent you a few e-mails.....lemme know.
Jon
Great Mike - thanks. Got your e-mail.
You've always been a pleasure to deal with so I figured you were busy.
Hey guys, thanks for your replies!! I wont be needing a chip anymore cause I just sold my GN :frown: I'll be hitting ya up for a few more parts when I get another one though Mike!! Thanks ----Jeremy
