CK's updated shift kit.
Steve V
Steve V's Automotive 757 560 2782
I got one of CK's new kit's today. Nice updates! Can you explain when to use the " A" springs and "B" spring in the kit for the 1/2 and 3/4 accumulators.
I also noticed that the line base spring is different for the old kit,it looks exactly the same as the accumulator spring. Mistake?
Thanks for any input,you products are great!:wink:
both springs are the same.it works great like that and eliminates bumpy mid throttle upshifts and kickdowns.the 1/2 accumulator spring update was done partially because of data you supplied regarding too firm upshifts.same goes for the 3/4.the softer 1/2 and 3/4 springs should be used with stock or modded d5 converters,and the others for 10.5 or smaller diameter units.
