- Feb 18, 2006
Does anyone know a way to configure the temperatures on the air temp and coolant temp graph? I don't think I will need to monitor 12000* inlet temp.
TIA
Rick
TIA
Rick
SignUp Now!It was letting me save before. Not by my laptop but I got it from the fuelairspark website.
Hi Rick
Until a downloaded and installed C-Com software is connected to it's respective Classic or XFI box it is in demonstration mode and will not let you save. If you copy over the files from the Config sub-directory the demonstration mode will now be converter with full rights.
how do you copy over the files from the config sub directory?
Do not attempt to do this if your version of software has been updated and your using a config folder from your previous version of software, as you can cause corruption in the program, and you would;nt want weird things going on...
