Cleaning out the garage, make offers
jdpolzin
All parts are 86/87 parts unless stated
1. stock Innercooler
2. throttle body (complete with sensors and throttle cable bracket)
3. complete set of stock pistons and rods 50K miles on them
4. main accessory bracket
5. alternator
6. a few power steering lines
7. tensioner pulley
8. AC compressor
9. 2 sets of complete 8445 heads
10. metal vacuum hardlines drivers side
11. electric fan
12. metal vac lines pass side with PVC and hoses
13. Compete set of turbo rods, no turbo pistons
14. fuel pressure regulator (stock)
15. oil cooler adapter + lines
16. 1/4 glass windows (chrome for vynal top)
17. Inner cooler fan (2 of these)
18. Inner cooler brackets
19. boost solenoid with Y vacuum lines
20. Vinyal top chrome trim
21. hotwire to alternator bracket
22. Battery postive wire
23. Battery negative wire
24. All the EGR components
25. turbo inlet bell
26. Down pipe elbow
27. MAP sensor
28. 86/87 heater core
29. heater control valve
30. maroon carpet dash cover
31. Charcoal canasters
32. Vacuum boosters
33. stock upper control arms
34. heater box fan
35. 85 Chrome Regal grille (NICE)
36. IC bracket (drivers side) (2 OF THESE)
37. IC Bracet (passenger side)
38. INJECTORS (42.5# set of 8, low miles)
39. Lisence Plate bracket (rear)
40. License Plate Bracket (front)
41. CAM Sensor w/cap
42. CAM Sensor w/o cap
43. Converter/Flywheel Inspection cover
44. Stock Starter 34K miles
45. POWERMASTER (Cardone Reman 2-3 years old, Accumulator went bad, otherwise good)
46. 14 bolt oil pan (Cleaned and painted black, non-baffled, NICE)
47. 14 bolt oil pan (non-baffled)
48. 20 bolt oil pan (baffled)
49. AC Delete pulley (2 of these)
50. 4.1 Stock pushrods
51. 14 bolt front cover (cleaned needs two bolts drilled out)
52. 20 bolt front cover (ready to go)
53. Oil pick up tube
54. D5 Torque Converter (34k miles)
I will update as I dig more out. Just make me a fare offer and they are yours. Take care -----Jeremy
I'm gonna need a good tensioner soon. Mine looks like its bouncing a little more than it should:rolleyes: Also need a good LT1 starter for the firechicken sometime if you come by one. I think after 2 years of it barely starting the car I should replace it this spring:biggrin:
and perhaps the D5
JD PM with price and shipping for both and see if we can work somthin out....dash cover for sure but if it dont fold then its a killer to ship price wise.
Mike
Vinyl Top Trim
Wutup Jeremy? on a scale of 1-10 how is the vinyl top trim??? i might need a spare...... lmk
Aaron
Update #1
5. alternator
7. tensioner pulley
8. AC compressor
11. electric fan
15. oil cooler adapter + lines PENDING
19. boost solenoid with Y vacuum lines SOLD
26. Down pipe elbow
27. MAP sensor
30. maroon carpet dash cover SOLD
32. Vacuum boosters
34. heater box fan
54. D5 Torque Converter (34k miles) SOLD
55. Chrome Parking light bezel for bumper (nice chrome)
56. Woodgrain dash bezel
57. woodgrain radio bezel
58. Floor Shifter assembly (no handle)
Either my power steering pump is making noise or it is my alternator. I'll check it out and get back to you but if you get a buyer before then go ahead and sell.
Interested in:
2 - TB w/sensors
4 - Main acc bkt
10 - Metal DS Vacuum Lines
12 - Metal P/S Vacuum Lines
41 - Cam Sensor w/cap
48 - 20 Bolt Turbo baffled pan
52 - 20 Bolt Timing Cover
Shoot me a price I can't look away from :biggrin:..... shipped to 39183 to my work (business address ... sometimes it is cheaper when shipping "to" a business)
I hope you also have all the bolts for above pieces?
Keep the offers coming guys, I want this crap out of the garage!
Update #2
3. complete set of stock pistons and rods 50K miles on them SOLD
5. alternator
7. tensioner pulley
8. AC compressor
11. electric fan
26. Down pipe elbow
27. MAP sensor
32. Vacuum boosters
34. heater box fan
Another Update---#3
7. tensioner pulley
11. electric fan
26. Down pipe elbow
27. MAP sensor
32. Vacuum boosters
33. stock upper control arms (rear)
34. heater box fan
59. Boost Solenoid
Does/can that floor shifter assembly include the cable and associated linkage to the transmission?
Adam, I actually dont have a shift cable or the bracket for the trans. I need to find a set for myself as well. This is just the shifter itself. -----Jeremy
