I'll check the gauges like you suggested and yes all the plugs gapped the same. I'll check the pcv tomorrow. Thanks for he help, Kyle.I have run plug gap all the way from .035-.020, tighter for higher boost levels. If you have a set of calipers you can check your gauges. Did all the plugs look the same?
I would clean or replace the PCV just to see.
