MIke was this the Ad?
Added: Wed August 10, 2011, 5:50 pm EST- (3) Stage 2 on center 053 blocks, on has big block chevy cam journals and .903� bronze lifter bores, pan rail is cut for windage(have pan/cam/ad jesel 903 lifters for block.(4.030 bore). Other 2 blocks are standard blocks that were run in nascar,(1- 4.030 bore and has roller cam bearings) the other one (4.000 bore) has been blown up and has the pan rail fixed where rod went through it, I have used it since and its still good.
- (8) sets of stage 2 heads, 6 sets use shaft rockers (I have one set t&d shaft and 1 set Crane shaft), other two use Jesel stands/rockers (I have one set of jesel rockers two sets of stands and some spares), all use 2.100 int/1.65 ex valves, I have some flow numbers or the heads but don�t have numbers for all the sets. One head of one pair needs repaired due to a dropped valve.
- (5) intakes, 3 sheetmetal,2 made by Tim cole, 2x4 and single tops, one Hogan with both 4150 single, and 4500 style single carb tops, 2 cast intakes with straight runners, one brand new from GM racing, other one run in nascar.
-(9) Roller Camshafts ( lifts figured with 1.65 rocker ratio)
Comp Cams 712�Int/ 708�Ex 110 lobe center in motor now so no grind #
Comp Cams big block chevy cam journal 840�Int / 760�Ex
Comp Cams 300-5 R6 690�Int/ 690�Ex
Comp Cams 318-6 323-6 R10, 735�Int/ 648� Ex
Comp Cams 100BJ/1307 R10RG 739�Int/ 709�Ex
Comp Cams 1303/1091 R13 J1731 739�Int/ 676�Ex
Comp Cams 324-6 336-5 R12 K9572 727� Int/ 693�Ex
Lunati 240-292c 109I3RC 729�Int/ 681� Ex
Cam Dynamics 320-325 R06 725�Int/ 650�Ex
-(3) Cranks
1 Crower Billet 3.58� stroke
1 Winberg Billet 3.59� stroke
1 TA performance NEW in box 4340 forged 3.625� stroke
-(3) sets of Rods
Set Billet H-beam K1 Tecnologies 6.350 with Arp 2000 bolts
Set New in box Billet H-beam K1 Tecnologies 6.350 with Arp 2000 bolts
Set Crower titanium I-beam rods with one spare
-(4) sets of pistons
NEW Diamond 4.040 bore 3.625 stk
Diamond 4.030 bore 3.590 stk in motor now new 6 runs ago
JE 4.030 bore 3.58 stk with pins PN 4014F
JE 4.030 bore 3.58 stk with pins and one spare piston
Others
2 (1 brand new) Buick racing timing covers(good ones), 2 stock timing covers modified and welded for gear drives, four oil pans one(hamburger) custom for block cut for windage, two ruggles pans road race, and one deep pan
Would like to sell as package for 17K but may seperate parts.
Call Alex
419-543-3315
*Seller Phone Number:* (419) 543-3315
*This item is USED*
*Trades NOT ACCEPTED* *Item Location:* MANSFIELD, OH
Contact Seller
*This ad expired 40 days ago.*
