87we410877
- Apr 5, 2005
I am using FEL-PRO 9441'S Do they need any coating before install? I installed head studs on the same set up as yours, what should final torque be when using lubriplate assembly lube on both sides of the washers and under the nuts. I purchased a new front cover with new pump from Johns performace in Wa. It came with no oil plate on the end of the pump, suggestions as to best plate to use when closing it up? Where to get the oil pump pickup seal (to the block), no one seems to have them? Also which valley seal is best to use Thanks in advance!
The gaskets dont need any coating. Torque is debatable. 85 max, 65 minimum is what seems to be acceptable. No idea about the front case. Do some searching on here or call Cottons as well as for the intake gasket. HTH.
		 and brakes wouldnt hold the boost at the line. Boost = 24
 and brakes wouldnt hold the boost at the line. Boost = 24 .i dont have any pics but if you want to see it im aound the corner in selden.
