Turbo Indian
worlds quickest 6cyl bird
- Sep 25, 2003
complete long block, complete from plenum, & throttle body to oil pan
this is the motor that is in the firebird in my signature.
2 center billet main caps
fresh 107M .010 main bearings (coated @ Calico Coating)
fresh 6-3768 .020 rod bearings (coated @ Calico Coatings)
Calico Coatings
bored .010 over with JE pistons
210-210 roller Comp Cams
Durabond cam bearings
double roller timing set
stock rods
ported iron heads
Ferrea big valves
Comp roller valve springs
cometic head gaskets
ported to match stock intake
ported to match stock headers
Harland Sharp 1.55 roller rockers
all port work was done by knperformance in Charlotte NC http://www.turbobuick.com/forums/feedback/199278-knperformance.html?highlight=knperformance
70mm KB throttle body "polished"
Precision plenum "polished"
RJC power plate
your choice of fuel rails, either a stock one, or one modified for -12 feed & fuel pressure guage relocated. (as shown in photos) "injectors not included"
ported, & powdercoated front cover
new GM waterpump
all you need is "your" sensors, injectors, accessories, valve covers, & turbo
$6,200.oo
Calico Coatings
stock rods
ported iron heads
Ferrea big valves
RJC power plate
new GM waterpump
$6,200.oo
