configure FP and EGT to PL
dank GN
BlackArts Automotive (661)993-8277
How do i configure the PL to read my transducer. .5v = 0psi 4.5v=100psi
also i will be hooking up a egt i have a 0-5 volt converter for it
First what FP and EGT amp do you have there may already be a setting for them in the PL
Connect your fuel pressure input to PL using Analog 4. Use NotePad to open the Powerlogger INI file. (The actual filename will be the same as the Powerlogger program.) The default is PLC.ini. Scroll down the ini file text lines until you see the [CustomAnalog4] category. Make the following changes:
CustomAnalog4MinVolt=0.5
CustomAnalog4MaxVolt=4.5
If the MinValue and MaxValue don't match your gauge, change them as well.
Save the file and you should be good to go.
