Connections at the starter / melted wires
TurboSmart
Lurking under my GN today I found 4 wires connected at the main power feed in the starter with inline fuses.
Gladly I found them because they were touching the downpipe!!
What does those wires power?
Any sugestion on re routing them?
I also found the main battery melt.
Any sugestions on how to protect wiring within that area?
Fuses, as in fuseable links? Or?
The main batt cable should be routed thru a retainer loop, on the frame.
A common cause of cable melt is the engine mounts are broken, and the engine is rolling over, onto the cable.
Heat sleeve is 1 way to protect the wires.
Stock fuse links. The identical as the one near the battery.
I wonder if I can extend them and use some sort of power distribution box near the firewall or somewhere else.
Maybe, here???
http://www.turbobuicks.com/forums/p...-link-relocation-kit-hd-alternator-cable.html
