Today I found a puddle of coolant under the GN. After opening the hood I could see a few drops coming from the bottom of the cone air filter. I check the hoses nearby and it appears that there are no other leaks. There is no coolant or water in the oil. My coolant level was low so I added some and drove the car to work. It's about a 20 min. drive and I kept an eye on my temp on the scanmaster, it never got above 193 degrees. Once I arrived it was leaking and continued for an hour or so then stopped. My coolant level is not really any lower so it appears the leak can't be too bad, but I don't know for sure. I took a picture to show where it's leaking from. Has anyone else had this happen before?
Thanks,
Brett
Thanks,
Brett
