- May 27, 2001
are you at the nationals this week Jay?
Nope.. Im 30 miles down the road and not even going. In fact, Ill be driving right by there tomorrow going mountain biking.
SignUp Now!are you at the nationals this week Jay?
really? i didn't realize you were in NC. Im down the road as well. I may go to piedmont drag way to watch em run. won't make it out to RC's b/c of work. Piedmont is withing 5 miles of my house. lol.
Instead of one gauge and cranking pressure you put the cylinder into a position where both valves are closed (or take off the rockers) and use a leak down tester (they have 2 gauges) and an air compressor for pressure...you air up the cylinder and then watch tge gauges, one tells you how much pressure you put in and the other shows you in real time how much the cylinder leaks...also you can look around and or listen to see where the pressure is going.
what about the chemical or gas test that lets me know if exhaust gases are getting into my coolant? where would i pick that kit up at? do you guys know of anyone who has used Odessa heads. they said call them with cast number and they will ship (remanned i guess) heads with new springs etc already pressure tested. if so, do you recommend them. I'm trying to keep mine a daily driver.
i have a issue with my car similar to this problem. its always worried me but i don't think its a head gasket.
Im current going back to the stock coolant bottle, new t-stat (same one has been in for 6 years), new radiator cap.
I have a alum radiator and it always sat alittle lower then normal. Seemed like it would put coolant into the resivor (razors bottle) but never take it back in thus lowering the level of coolant. I could drive it for days and randomly the temp would go up on my autometer gauge then suddenly shoot back down like the thermostat was hanging up or i had air in the system. XFi gauge would not so much change that i remember. The autometer gauge is pluged in right next to the T-stat (hotair car) and i have the water pump bypass pluged. I could make full 28+ psi track passes with no raise in coolant temp. Well it would go up maybe 2-3 deg. Its very random, Since reading this post i just ordered a leak down tester just to test as well. Figured since im replacing all this stuff might as well check and have a clear head knowing its not a head gasket. How much pressure do you put into the cylinder with the leak down tester? whats normal leak %?
If its a head gasket, no biggy i have a set of heads and a new cam i want to install anyways![]()
mine will do that that and then take forever cooling back down...sometimes its just as quick. either way, i've got 98% of what i need to get the job done...the other 2% is brain power. lol!
since they're cheap, i went ahead a grabbed another radiator cap. lol! i figure what the hell. if i do change heads, im gonna wanna new one anyway.
