Correcting for tire size and gears with a PowerLogger
TurboBob
Resident mad scientist
Staff member
There is a correction factor in PLC that will correct for tiresize and gear ratio changes.
It only changes the info shown on the PLC screen, and does not affect the Converter Slip calculations.
To correct the Vehicle Speed reading, do the following:
Close the PLC program and look in the folder for PLC.ini, edit this file and look for the following
VehicleSpeedScale=1
change the 1 to .9 or something like that and save it.
The next time you run PLC, the MPH reading will be corrected by this factor.
Bob
