Not sure if this should be in this section or the lounge, but Im curious how much the average build cost is. Start to finish. Obviously it depends on what you want to do with the motor. Ok So say I want a solid 11.50 car, but toss in some race gas and crank the boost up and spray alky and get into the 10's. What would a SOLID build like that cost?? I mean is their anyway to build a stout motor without blowing a HG or the motor itself up entirely?? Is there any so called a safe range/tune??I know most problems arouse when the boost is mostly over 20lbs, from what I have read over the years. Can you build a combo to run 11'50's and faster with under 20lbs of boost?? I know there is risk in any build, but there hasta be a solid build out there , thats consistant. I hear people say its very exspensive, but no numbers are ever thrown out there. So Im guessing what i want is a number( price) on a solid 109 build.
TIA
TIA
