Franks86gn
- Nov 15, 2011
Cracked below freeze plug on drivers side. What can I do with it?
Thanks.
Thanks.
SignUp Now!My first instinct was to get a junkyard 109 and freshen it up & swap everything over. New rings, bearings, & seals of course.
Thanks!Yes they are the same and the drain hole is 1/2 NPT.
my engine builder found a crack on the #2 register, going outwards from the cap bolt hole. said it would be ok for a lower h.p. build, but not for my goals. i got another block. when i asked him about the n/a blocks, he said they were not the same. he told me that the turbo 109's are beefier in the webs. can anyone clarify this?Off to the junkyard I go....
Just to clarify facts about the 109 block; After doing some searching I get that the NA 109 blocks are the same as the 86-87 Turbo 109 with the exception of the turbo oil drain hole.
If indeed that is true, what type/size is the thread?
Not everyone has the knowledge. I could not find anything "searching" maybe the next guy will come along and see this. I believe I made my mind up @ post #8 however, your attempt at sarcasm is of extraordinary magnitude. I'm sure you agree tooI really have no idea why I clicked on this thread being afraid of what I would see posted Never mind.. I'd take to long to type a sarcastic post. Get a new block for christ sake
