- May 26, 2001
In the past few years I have had issues with crank sensors and brackets that were never encountered before?
The first issue was with fitment and configuration of the bracket, as it would allow the ring to interfere with the plastic sensor. To fix this issue, I would need to grind the bracket to allow proper alignment.
More recently I have had issues with the crank sensor slots being out of tolerance, and in a few cases the ring would contact the side of the slot and actually remove some plastic and even slice the side of the slot. I chalked this up to my eyes getting older and maybe mis-aligned the sensor?
After 25+ years I finally purchased a factory crank setting tool for a lot less than the original price of $700-800.
So I of course wanted to check out my new "toy", so I tried it on a spare engine with a crank sensor and it would not pass through the slots as it should? A new sensor/bracket out of the box was installed and still would not pass through the slots?
The third new sensor, different brand, worked fine as did a used one.
With a close inspection of the bad sensors, it was apparent that the slots were not parallel, and not wide enough for the ring to pass w/o damaging the sensor.
I do not know if the "bad" parts were made off-shore or not, but this is another case of replacement parts that are different physically from original.
At least now I have the ability of checking different brands, and not trashing a new, expensive part.
