X2progress looks great !!! can't wait for the final photos . you are blessed with fine craftsmanship . keep up the great work...
Here is something written by Berry from SPI that i think you will enjoy. I use a Awata 400 LPH with a 1.3 cap.It looks really good. what spray gun? Tip size? and psi you using please. I'm not seeing much orange peel at all.
My gun is Devilbiss finishline FLG3 with a 1.3, 1.5, 1.8 and 2.2 mm tips and I shoot at 10-11 psi at the gun. I get
real smooth coverage on the basecoat using the 1.3 mm tip. I'm getting more orange peel than I like to see when
I shoot the clear. It helps some to increase air pressure, but I'm still spending a lot of time wet sanding. I know I'm not using
a Sata...but dang. Today I shot a bunch of parts with the SEM trim black and everything came out really smooth and
factory looking using the 1.3 mm tip. Just wondering if you have some secret method shooting clear that I'm not knowing
about. Smaller tip size maybe?
Thanks,
Howard
The gun will make a difference. That is a cheap gun. It might need more air pressure than they recommend. Also adjusting in the fluid will help. Pattern size makes a difference as well. I spray base and clear with 1.3 Sata's. I have a old Sata NR95 with a 1.5 and it sprays finer than the 1.3's. It is my sealer gun now, and when I spray solvent base I will use it.It looks really good. what spray gun? Tip size? and psi you using please. I'm not seeing much orange peel at all.
Thanks,
Howard
