I put 10 on a engine that was blown up because it was stolen. Rebuilt for e 85 hardly a few parts
Sent from my LG-LS980 using Tapatalk
How about pressure dropping because there is a return line.
Im sorry my pressure went up after i changed to a bugger pump.So in my case i had to much fuel pressure in the beginning couldn't bring it down enough. I added a new stainless 1/2 inch main line for larger supply of fuel then pressure would not go under 50 psi. So I used the original main as a return and this brought my pressure down. So is my fuel regulator bad? This is a brand new accufab ?
Do you even have a GN or a TA
Ok before you buy anything contact me ill give you whatever you need if i have it. Fuel lines fittings translators data logger or Scan master Casper caps ill give it to you free.Alright...it's time I get to the bottom of this! I had my motor built by Nick Micale and he told me he installed (and hot wired) a DW300 or 301 (apparently they're the same) fuel pump at the time. But I'm having a very consistent issue with not being able to run above about 14 psi boost.
What happens perfectly *very consistently*, is right about 14 psi boost, it cuts out. Running E85, and initially only having 60 lb injectors, I thought that might be it. So I upgrade to 80 lb injectors, and a new TurboTweek chip to match, designed for up to 25 psi. No change at all...still basically a near totally loss of power at 14 psi. It really feels like it's not getting enough fuel.
I know, I should probably have a scantool, but I do not. If I have a run where I stay below 14 psi, it feels *perfect*, and generates great, smooth power, and the Scanmaster reads around 800-820 O2 MVs. However, if I stayed in it once or twice briefly for a couple seconds through the power loss, and the MVs were dangerously low. As I remember I saw a high 600 and a low 700 once. So now, not only there's no reason to, I let off the moment it happens.
So...in talking with Nick, he thought maybe it was an insufficient ground to the fuel pump. I added a 10-guage ground to the stock ground and it had no effect at all.
At this point, while I can see that the fuel tank straps appear to be in a different location than originally, suggesting the tank was dropped, I'm thinking that he made a mistake and didn't put in a DW300/301 FP.
But that's why I'm writing this thread. Because I'd like some feedback on other possibilities - before I buy another DW301 FP and drop the tank, assuming I need to install one. There's a hell of a lot more power in this motor asking to be unleashed with another 5-6 psi. Well, of course I know I could go higher than that with E85, but at this point, I plan on keeping the car for years, and don't want to stress the motor that much. I'm sure I'll be happy with 21 psi for a while.
So...any suggestions? Again - it runs perfect up until 14 psi, and then - it's flat on its butt. I took it to an 1/8th mile track and raced my buddy last Fall in his stock 2015 Camaro SS (426 hp), and had him by 1-2 car lengths all 4 times we raced. I had it set for ~15 psi, and when it cut out and went flat, I'd back off to ~90% throttle, and the car would take off again.
Last thought: I believe Nick installed a new stock style fuel filter too. Are those okay flow-wise for E85?
You needed a larger RETURN line.Im sorry my pressure went up after i changed to a bugger pump.
Wow, went on a cruise for a week and you still haven't fixed the problem.
I'll just be here eating my popcorn for further entertainment.
Just think if it left the shop "CORRECT" we wouldn't have any entertainment
At this point who's to say it didnt. Seems like a intermittent problem and maybe it didn't occur when nick had the car.
Then again maybe it did we don't know. We need to have the OP to test the regulator still with pressure to the port and or swap it with a known good unit and if that doesn't fix it it's time to drop the tank
I appreciate your diplomacy .. However If you read the OP's posts ( CAREFULLY) ... a lot becomes very very apparent . I am not throwing anyone under the bus nor do I care to get into that drama .
I can tell you this I FULLY AND 100% can say the OP has been very transparent and has posted to a very high level factual information that I think makes things cut and dry .. and I am willing to help out in any way I can to help him resolve the issue ...
It's not hard to figure this out at all .. it's simple step by step diagnoses that is so routine with these cars its not even funny .
What we don't need is guys muddying up the thread with their own car's problems and having this guy go off on tangents ..
To the OP .. if you need tools or scan equipment or whatever .. let me know .. I'll send it to you .. if you were closer I would help you drop the tank and take a peek
( HINT HINT ) .. I know what its like to not have spare time and wanting to make the most efficient use of what free time you have.
Let us know how we can help
