Unplugging the cam sensor (while engine is running) will put the fuel injection system in 'batch' fire mode instead of the normal sequential mode.... and will, for the most part, verify the cam sensor is not part of the problem.... if it still runs like crap in batch fire.... and don't beat the crap out of it while in batch mode... just do what's necessary to verify the problem is or is not still present... and remember, the engine will not restart with the cam sensor unplugged if you shut it off.... :wink: FWIW, in my opinion, your problem doesn't 'feel' like a cam sensor problem to me.... I would start below first...
I haven't seen anywhere where you've verified the fuel pressure is responding correctly... should be 43 psi at idle (with the vac line to the regulator off and plugged) and, (reconnected) rise 1 lb for every pound of boost while driving. You MUST verify this (will rule out fuel pump/related issue), and if that checks out proper, then the next most likely culprits are:
1) Bad maf, as mentioned, remanned are hit and miss at best... also make POSITIVE the hose from the maf to the turbo is intact and leak tite...
2) Ignition module/coil pack weak/failing..... a VERY common malady for these cars as they age... you can check the coil pack by connecting an ohmeter between front and rear cooresponding coil towers on each pack and verifying the reading is between 11k and 13k ohms... this test will catch 'most' bad coil packs... no way to test the module without Casper's tester, so it would be nice to find a known good spare to swap it out with before you buy a new one, as it is fairly expensive for a OEM GM Delco module, which like the maf, is MUCH preferred over remanned...
HTH...
all of the above will cause the symptoms you describe....
.....And Welcome to the Darkside....
