bmackinnon
- Feb 24, 2005
Thanks for your time and answers to my questions. I have a friend that has that casper tester for his TR and I can use it. I was thinking fuel pressure but I cant see what its doing while driving. What will happen if the fuel pump is going out.. Is it all or nothing, or go out slow over time?. It has a hot wire kit but I dont know what pump is on it... Thanks alot for the info...
Typically, the failing fuel pump will work ok for a few minutes (10-15-20min?) until it starts getting hot, and then start falling off... also the (failing) pump will often support the fuel required for idling/(or revving in neutral
Excellent news with the casper's tester.... pull your module/coil assm'y off and put the tester to it!!
