just painted one got another to do should have took before pic, had to lightly sand with 600 to get rust off don't go too hard or you will ruin the texture, rust bullet or evaporust works good too as a step in cleaning , paint is 1598 dark grey from gbody looks pretty good
to get the lock latch of you'll need a tiny screw driver to push the five pins in the lock as you pull it out , done from the inside there are two access point one on top and one on the side if you want to go from the top you will have to turn knob to open position the side access point is for closed position
