dconnor.  what is your setup?
my car is why too slow, in my opinion.  I haven't been to the track yet but I have ran it a couple of times using my gtech.  14.2 at 103.  I'm not how accurate it is.  The Gtech was in a pretty bad accident.  Gtech co. says it doesn't need to be calibrated.
My setup is PT52, THDP, Joe Lubrant 93 w/20 degrees. 36# injectors, stock converter, cat cutout.
I just purchased the car so I am in the midst of fixing it up.  Fuel Pressure reg, 50# injectors and fuel pump are next.  Then maybe a 3000 stall.
I figured the car was running high twelves by the way it feels but the Gtech states something different.  If the 103 mph is correct, that should be low 13's.  I would be happy with that considering the stock fuel pump, stock regulator and 36#.
What do you think?  My goal is low low 12's or high 11's.
