No don't care to share right now until I actually have time and results on the setup ...
Mike I have no problem posting up after I can back up what I know is going to happen with actual time slips .. I can tell you this with the limited time I have on the setup ... it feels like a high compression NA small displacement motor .. it revs instant and spools instant .
Primary usage is street car .. track performance is secondary ...
Again I have to stress the de-stroking is just an enabler and requires a different approach vs the traditional. Which as you pointed out earlier this thread was posted with a CANNED answer ... the reality as we all know if you do de-stroke and follow through with the entire process.. you WILL have a setup that IS FASTER / QUICKER ... by how much ? Well hopefully I can answer that in a few months .. Only reason I even did this was things I learned in the past with a Turbo SBF and having a short throw BMS crank laying around . I have no doubt it will run away from my previous 3.8 setup ..
PS your engine builder that's giving you the info sounds like Sherman
... Guy ROCKS !
