Jul 17, 2010 #1 M Myty New Member Joined Sep 24, 2008 Messages 30 I put a Auburn chuck in about 9-10 years ago. I had used Mobil 1 fluid with no chatter or breakout ever! I put in the same 75-90 in a few weeks ago and it chatters Bad. Please give me your opinions. Thanks
Jul 17, 2010 #2 S Slow91z Turbobuick.com Helper Staff member Joined Aug 7, 2003 Messages 3,758 No idea about Mobil but as for the car just add some posi additive...Shouldn't be a big deal.
Jul 17, 2010 #3 W whitehot1 Well-Known Member Joined Oct 24, 2006 Messages 4,682 Just add this to it and you should be good to go. Trans-X® Posi-Trac® Limited Slip Gear Oil Additive by K & W Chemical - Part 402508 - Advance Auto Parts
Jul 18, 2010 #4 M Myty New Member Joined Sep 24, 2008 Messages 30 Thanks! I had thought I found the perfect fluid for the job and its synthetic. Additives in synthetic concerns me with Posi Break out on slicks.
Jul 18, 2010 #6 G GNeric Senior member Joined Jul 26, 2003 Messages 2,926 My guess is terminology like "full race cam". :biggrin:
Jul 18, 2010 #7 1KWIKSIX Well-Known Member Joined Sep 29, 2007 Messages 3,236 Synthetic Oil in rear end Myty said: Thanks! I had thought I found the perfect fluid for the job and its synthetic. Additives in synthetic concerns me with Posi Break out on slicks. Click to expand... Had a new Auburn Pro Series Diff installed last year. In the installation instructions Auburn state "Do not use synthetic oil" in the rear end. Guess it's too slipery. The Posi unit needs a certain amount of friction to function properly and synthetics will cause excess slippage. Use a good dino oil and GM's rear end posi additive and you'll be fine. dave
Jul 18, 2010 #8 D Dabigguy Pompous azz Joined Jun 1, 2005 Messages 3,028 GNeric said: My guess is terminology like "full race cam". :biggrin: Click to expand... I could never afford a "full race" cam when I was younger. All I could afford was a "3/4" cam.
Jul 18, 2010 #10 M Myty New Member Joined Sep 24, 2008 Messages 30 Full Race. LOL!! Break out = Posi to a one legger. When doing a line lock heat up. One legger= One tire fire Thanks
