SignUp Now!Ok, here is where I am at now with the No-Load flasher from spaghetti.
All the functions WITHOUT the runnings lights on work properly but the blink rate is faster than stock and also the video on injectionX.
When the running the lights are turned ON and the blinker is applied the outside board blinks. It goes bright and cascades off with dim running light staying on while the cascade effect cycles. That is proper.
It is the inside the board that doesn't seem right. Once the blinker is on with the running lights on the inside board goes into a regular blink from bright to dim while the outside board is cascading. If you apply the brake the inside board goes steady. On the video on injectionX they do not show what it should do with the running lights on and blinker applied.
Is that the correct function? I just wasn't expecting the inside board to blink at all. It seems that the operation (blinker wise) should be the same with or without the running lights on.
Scot, I know you're in BG so get back to me when you get a chance.
Yes brian, Yours are already on there way bud!still no comp # . Has mine shipped yet . If not I would like to cancel my order and get my money back. I'll purchase them once you get the bugs worked out.
Thanks Brian Verson (618) 973-0297:frown:
You should be able to get them at any auto parts store. Also read the instructions real close concerning the flashers. It says to replace the BI-METAL flasher with either a STANDARD flasher or a NO-LOAD flasher. It is very important to have a good ground off the flasher. The standard flashers might work just fine. (Tooch) usded a Heavy Duty flasher and it says in the instructions that the LED's will not work with the Heavy Duty ones. So make sure it's not the Heavy Duty flasher!!!!wherelse can we buy the no load flashers in a hurry-i want to complete my installation this thursday and dont want any delays? pep boys? anything special about these except for the ground wire?
Thank you!I was unable to find a no load flasher at any of the out parts stores near me in MA. AutoZone, Napa, Advance Auto parts. They all carry a variable load but you need the no-load. You can tell the difference because the no-load has a ground wire coming from it.
You'll see a very easy location for the ground wire on the metal wire harness when you remove the AC-heater blower vent under the steering wheel.
The flasher is just to the right of the steering column.
Scot, I'll get that video to you tomorrow of my lights in action.
Go ahead and rub it in!! :biggrin:i finally had time to finish the install yesterday... i took my time - soldered everything, used weather pack connectors so i could easily remove or work on things... fit and finish are great... but i cant drive b/c they arent working properly..... yet - i ordered the "variable/no load flasher" on the 13th - called em today to see whats up - i think they forgot to send em - b/c the tracking number they gave me said it was shipped today
- Well at least my wiring looks good:biggrin: ... cant tell you how the cascading looks yet
regardless - I applaud Scott for taking the initiative and time to get this thing together ----- hell he doesnt even have a buick anymore
thanks again - i cant wait to get everything working.![]()
I just go off the phone with the owner from spaghetti engineering and that was actually an added feature to increase the visability and saftey of the turn signal.Ok, here is where I am at now with the No-Load flasher from spaghetti.
No you didn't mis a post. Those of you who have them now will have to see if your local auto parts store has them or they will have to be ordered from the company. they will only be included in the future just because it looks like these cars Will need them. The only reason they were not included from the beginning is because the owner of Spaghetti engineering said some people will need them and some people won't depending on the flasher in there car. so thats why they were not included.Did I miss a post about those of us that already have the kits and no "no load" flasher? Will we be sent one?
