scot w.
GNSperformance.com
- Feb 19, 2005
Roger, Did you purchase ONE flasher or TWO?Scott,
I have hot checked the lights. The brake lights & the running lights & the hazard flashers appear to work correctly.
The turn signals, right or left act like hazard flashers. No right or left, only all of the lights flash.
I wired per the wiring diagram & wonder why the green lead is hooked up on both sides & the yellow lead is hooked up also on both sides. Is the wiring diagram correct?
Roger![]()
If you have ONE flasher- It MUST replace the OEM flasher that is located Under the steering column!! and NOT ON THE FUSE PANEL!!
If you have TWO flashers- You can replace both the OEM flashers located Under the steering column & The one located on the fuse box.
"ONLY ALL OF THE LIGHTS FLASH" ??? If you can, Please go over all of your connections again because it is something really simple that isn't hooked up correctly or that LED flasher is in the hazard spot instead of the turn signal spot. Either way, It is something to do with the install..
Roger give me a call tomarow and I will help you fix this issue..
Scot W.
(865) 680-4008
