Jay Nesbitt
Lurker Member
- Apr 22, 2003
*DIRECT DRUM:
The direct drum must be within .030 of original diameter. Cannot be bent or heat deformed. DO NOT drill holes in band surface. This does nothing but add problems with band oil, the direct clutches slinging their lube out, and I have even seen them crack from the holes, and distort the actual drum itself.(Like a brake rotor) Weakens them immensly. All steels must slide freely in bore. In ring bore, no ring cavities can be present. One of the most common 2-3 flair symptom is , bore is ring grooved near bottom of drum using cast iron rings. Band surface must be PERFECTLY FLAT, no scores, especially with the use of the new band. ...
OK, I certainly appreciate the good advice here on the 200 4r. I am trying to abide by it , referring to it as I reassemble the trans...I could use some help, here. Am rebuilding a spare tranny for use in my T, and the direct drum is not "perfectly flat" without scores...So I went to the tranmission wholesale rebuilder with whom I've traded for like 15 years....no more direct drums...just a couple of refurbished (welded. turned/polished) ones...wrapping a band around them and measuring end gap (with my hundreths scale which i had in my pocket protector-bet you think I'm kidding-nope), my used scored drum was still .016 in dia larger than the ones they were trying to sell....I didn't bite....
So.....
1. Where can I get a new (or good servicable) drum?
2. What is original dia and I'll throw mine on my lathe and resurface it ......and I can see it it'll clean up at <.03 under.
Thanks,
J Nesbitt
So.....
Thanks,
J Nesbitt
