68ElCamino
- Sep 29, 2010
Can the slots that mate up to the sun shell tangs be repaired? Want to add material with mig welder and file to to make them right. This is the 3rd drum I have bought that doesn't meet the standard. First one has bad wear on bosses where the piston sits on the bottom. Second one has ring wear in bore. This one is worn on the tang edges as mentioned above.
Thanks again,
Joe
Tangs on sun shell measure 1.025 wide. How much larger than the tangs should the slot be?
Thanks again,
Joe
