phil_jordan
- Aug 22, 2012
i have 42lb injectors with stock turbo what kind of turbo can i step up too? with stock convert?
I'd maximize the stock turbo first before I go changing it out. The stock converter was meant for it, and although you can get away with stepping up a little in size, your spool time will be affected, unless you go ball bearing...then ignore everything i just said.
