Does shield fit on bigger turbos
MSDGN
I'm assuming most don't use the shield when using the bigger turbos...at least that's what I've seen but will the turbo shield fit on say a 70 GTQ?...also can the question mark(?) bracket for the turbo still be used?
Cal Hartline runs one on his PTE88 turbo,you need to trim it a bit and make a bracket from the head to hold itfrom behind
I run a stocker with my 70 GTQ. The bracket will need to be lightly modified for the shield to work.
