May 25, 2005 #1 M MSDGN Active Member Joined Jun 8, 2001 Messages 2,140 I'm assuming most don't use the shield when using the bigger turbos...at least that's what I've seen but will the turbo shield fit on say a 70 GTQ?...also can the question mark(?) bracket for the turbo still be used?
May 25, 2005 #2 O Otto J Well-Known Member Joined May 31, 2001 Messages 10,546 Cal Hartline runs one on his PTE88 turbo,you need to trim it a bit and make a bracket from the head to hold itfrom behind
May 25, 2005 #3 L Louie L. Habitual Line Stepper Staff member Joined May 24, 2001 Messages 4,249 I run a stocker with my 70 GTQ. The bracket will need to be lightly modified for the shield to work.
