Doing away with hydoboost...or not?
workinonit
87 Astro roof GN
May be a dumb question but, If I wanted to swap out the hydroboost for regular vacuum assisted power brakes, can I just take a master/booster/pedal setup from a Regal and put it in the GN ? I've seen "kits" on ebay and elsewhere for big bucks...what else does one need or have to change? Thanks.
There have been a bunch of people around here switching TO Hydroboost...If you have a good working hydroboost, I would use it.
I believe you can do this.
Absolutely, unequivocally, yes..... will also need 3-4 ft. of 3/8" vac. hose, and a 3/8" plastic 'T' to T into the PCV line and run to the booster. That's it.... :D oh, and a contortable body to get under the dash.... :)
If you are one of the fortunate PowerbrakeBob sales pitches that blew up with crappy everything then ditch it now and stop waiting.
New 87 NA Regal ms/pb with that pedal and a vacuum block from Caspers will be all you need.
