Door handle gasket install?
DKREDT
Any experts out there?
I put new door handles on my car after new paint. There is a plastic "wrap around" "gasket" that helps keep water out of the door that is viewable underneath the outer door handle.
When I buttoned it back up, the door handle is as stiff as can be and has lost it's "springy-ness".
Is there an adjustment for this?
Anyone out there messed with this before?
TIA!
Joel
Sounds like it's on backwards. Had similar trouble with mine. Try turning them around. They are a must have. Without them you can see right into the door. Looks real bad w/o them.
John:
You were right on! I finally gave in since I dont have time to mess with it... my bodyshop confirmed what you said. I had it on backwards. :)
