I was wondering??? My cam started to eat into the front of the block, and I've decided to add a Torrington bearing between the two, I noticed the oil passages are right behind the the thrust surface of the block, a small hole drilled on either side would direct oil to the bearing. Would this cause any major problems? Any suggestions? Thanks, John.
