Driveshaft Sensor and XFI
karolko
After Reynolds, i have decided to run a driveshaft sensor on the GN.
My question is are they all the same or are there better sensors than others.
I was recommended the Edelbrock sensor due it it's cost. anyone have experience with that one on a 28 spline 9" Stronge yolk?
what is the difference between the 2 magnet and 4 magnet collars?
Thanks guys,
Adrian
I'm running the 2 magnet one from Cal which I believe is from FAST. You have to know the OD of the yoke.
Billy T.
gnxtc2@aol.com
"what is the difference between the 2 magnet and 4 magnet collars?"
Resolution?
Thanks guys,
Adrian
Don't use the edelbrock sensor. I already tried and doesn't produce a strong enough signal for the EFI to read. The edelbrock sensor is an inductive type using only two wires.
The FAST sensor is a Hall effect sensor and requires a 5V power source in addition to the two sensor wires. The Hall effect sensor seems to work much better because of this.
Allan G.
