SignUp Now!what driveshaft shops do you guys recomend in san diego? and when should i upgade? car runs 7.8 @ 90mph in the 1/8 with 1.8 60' but going to start launching on tbrake
My crank broke in half before my drive shaft did. 10.80's 20psi tbrake launches.
I thought stock cranks were good for 9's. :biggrin: Shows what I know.
Neal
I thought stock unopened 109 blocks where good for mid 9's with the right stall, and turbo. :biggrin:
What times where you running? And what 60' times? off the trans brake I would assume? Has anyone heard of a Eaton Posi unit not holding up when using a trans brake? Is this commn because I also have to upgrade my open diff and stock axles. thinkng of going with eaton posi, 30 spline moser and c-clip elimns from strange...... any input?
I just pulled the driveshaft out right now so I could take it to the driveshaft guys tomorrow...... but that driveshft looks pretty beat up. Its got rust everywhere and I dont think it could take anymore. So you guys recommend going with a 3 " with t-400 yolk and spicer u joints right? hopefully its not to much!
