Phoneguy
Cometic HG stress tester
- Aug 27, 2002
SignUp Now!I gave up on coolant as well. The bodyshop left my car outside overnight in 14* weather, no ground for the fuel pump when the bumpers were off so he couldnt get it started, popped 2 freeze plugs !!!!!!I even gave up on coolant after the first HG blow, but then worried about RMI cleaning the system too good and clogging the thermostat on my GN and 67 Mustang, but so far, so good.
It is.. until it leaks.. never figured out while people would skip steps that have been proven.. trying to save $10 on a can of copper spray ?
A lil coolant in the oil never hurt anything
Don't mind us guys with decades of experience.. whats the worse that can happen... coolant in the oil, wiped bearings... don't waste the money on a can of copper spray.. better to redo a leaking gasket with new intake, valve cover, and exhaust gaskets, not to mention oil and coolant and 5 hours of work ... The auto stores, vendors, machinist and engine builders thank you. Four jobs on stock finish head/block and no leaks on mine..others... installer error ???
If I laughed at the ignorance on this board, they'd call me the court jester!
jasjamz said:JW, time to upgrade that boost gauge...yikes!
I'm in So. Cal.. so no worries.. headed home to MI soon after 15 years, so unfortunately the GN will have to reacquire the taste of anti freeze
30 hg to 20 psi gauge ;-)
past the 20 psi and back around to 30 in...LOL
Phoneguy said:Jason , with the car being for sale are you stepping up in class or getting out of the Buick class racing all together ?
Bryan
Best of luck to you!!! The races wont be the same without you and your brother there....Focus on business and the other shop car that my brother owns.
