Dual Intrepid Fans Vibration
klmnla
Watson LA
I have the dual Intrepid fans and caspers harness from Kirbans. When the fans are running, I can feel the rumble throughout the inside of my car. The fans are installed tightly against the fins and tightly between the tanks with no movement. Anyone else seen this? Do I need to isolate the contact with the radiator with rubber or a gasket of some sort?
When I installed my intrepid fan, I used a self adhesive weather stripping tape around the edge of the shroud. Never noticed any vibration or rumble sounds.
You'll find most electric fans have a small metal clip attached to one of the blades. This is for balancing purposes. Yours may have come off.
Sent from my iPhone 6+ using Tapatalk.[emoji252]
