I've made my first shot at a jig to allow drilling your block for the Duttweiler style roller cam thrust retainer. It requires drilling 3 holes on the front face of the block around the cam and machining the cam to fit. Once this is done, you just bolt it on...no shims, no button riding on the inside of the front cover. I like the simplicity.
Here are a couple of pics of the jig. I've got to order drill bushings, verify that it's accurate and do my block; then I will make a couple of these. You can buy the retainer plates from Duttweiler and most cam manufacturers should be able to deliver the cam with the nose already machined as an option. I'll try to take pics of the nose machining and provide specs for anyone who's interested.
jig with cam journal mandrel
retainer plate and screws
