Duttweiler Twin turbo V6 1000 to 2000 HP
Ok guys big misunderstanding he meant looks really good with 1083 horses pulling it down the street in a parade.
Maybe he meant 1083 to the crank. Bison put 700 to the wheels with a stock stroke 109 and a single 66 on pump gas/alky. AT 19 psi I can only assume he meant to the crank tho.
since it is a 242/250 solid roller, he may be running it 7500RPM+ It may be posssible to make the power up there, at 5500 rpm on pump gas no way
Mike
Solid rollers are so street friendly.. :eek:
If it where my engine I was selling, I would have put the dyno graph up on the add. Whats an extra picture .50 cents?
And.. Cant compare stock heads to stageII heads.
1083 on the dyno is like 900 RWHP? This is way more power than any supercar on the planet makes on low octane pump gas. Even the Bugatti, Saleen, etc.. hence why I said.. BS ;)
Bison had octane. And ~300 HP less. Thats a long hill to make 300.. given similar displacement.
I'm right there with you.
