DW Pump & E-85
With ample voltage supply and modest fuel pressure expectations (~65psi) the pump could deliver required ~70gal/hr to support 500hp.
the DC will depend on the tuner and what is being run for pressures.. there is no magic number to shoot for as far afr .. a lot depends on what your using for a sensor and where its located... typically I see 10.9-11.4 work very well .. but ive seen at least 1 car make the fastest passes @ 11.7ish on the same wideband as others have been @ 10.90 ... Also what the E85 test out at .... that pump with a 80 pound siemens injector and TT chip is simply a unreal setup to beat .. idle, drivability , WOT power is phenomenal .
I can't say enough about those pumps/ injector / chip setups ..
thank you sir for sharing this info....i think theres alot of members who like me come in and read alot but dont really post/ask alot of questions :)
