- Nov 24, 2001
Reading this page reminded me of a guy at the track.
He was running a diesel compound setup(duramax) with a secondary 114 turbo.
They could not get enough supply to the motor with the stock gear driven high pressure pump, so they used a factory fuel pump off a belt drive to get more fuel to the motor.
I talked with them, yes it would be bad if the belt broke, but its a diesel.
Food for thought, what about running a belt drive fuel pump for more supply with the alternative fuel you guys are running? The duramax fuel pump was the same size as our power steering pump.
BW
BW
